I have an LG Esteem running Android 2.3.4.
I went to change my ringtone went into settings, ringtones and get
the following message.
The application settings (process.com.android.settings) has stopped
unexpectedly. Please try again.
then force close.
If anyone has had this problem or know how to get it fixed Please Help!
My phone is rooted and I am using Backup Pro to backup all my apps and
data because all I've found is lots of people saying to do a factory reset.
This is not an ideal solution since everything works but, being able to
get into ringtones....even notification work......
Again, if anyone can help me that would be great!
David
then force close.
David
