Hi, so I installed metamorph and when I click to start checks it gives me the following error: "Some files could not be extracted and set up. Please make sure you have enough free space in /system and that Busybox is installed!"
I checked the /system, I had about 20MB free space, moved some stuff and got to 30MB (useless stuff like the Corporate Calendar, etc ... I saved it elsewhere in case I need to move it back). Anyways, that didn't work. So next I tried downloading another version of busybox through Titanium Backup, still no luck. I googled the problem and tried entering this code in the terminal emulator:
Fix busybox
su
mount -o remount,rw -t yaffs2 /dev/block/mtdblock4 /system
chmod 755 /system/xbin/busybox
mount -o remount,ro -t yaffs2 /dev/block/mtdblock4 /system
sync
reboot
...but when I enter "Fix busybox" I get a permission denied message ... still tried the rest of the above code and Metamorph still isn't working. Any ideas?
Fix busybox
su
sync
reboot
