Help Can't get pdanet tether over bluetooth to work!
gainnid
Got it to work over usb but can't seem to figure it out how to work over bluetooth. I can find my phone under devices but it has nothing listed under device function or bluetooth services. I was able to send my phone a file from my computer via bluetooth. My phone also says under bluetooth devices it's paired but not conectected to my computer. I'm running windows 7. Anybody have any ideal?
That is only for paid & registered users, correct?
You are running 2.1 correct? you can't do pdanet tether over bluetooth with android 1.5. you'll have to go for the leak or wait for the OTA to do it.
I am in the same boat..
My laptop (running vista 64 bit) is connected to the phone via bluetooth. Attempting to use the PdaNet Bluetooth DUN to connect to the internet. When I look at Network connections under dial up I have two choices Bluetooth Connections and PdaNet Modem. I have tried each, put in the number to dial as 123? as it said to do on the PdaNet help page.. and it fails to connect.
Any recommendations?
Yes I am running 2.1
(I may at some point just say screw this.. root the damn thing, and go wifi and not worry about it, But until I work myself up to that.... help??)
Thanks
