chick3nstrip
OK So I just downloaded from the market the usb webcam app, and then it says go to placaware.com and download it to your computer and then it says "Make sure that the Phone USB driver is installed correctly. Follow the instructions by Google, or if you are experienced, in the device manager, install a driver for
