Root Cant mount sd card clockworkmod recovery
toddio
I am trying to install cyanogen mod and already flashed clockworkmod recovery via nvflash. now when i boot into recovery and try to make a backup it says cant mount sd card. anyone know how to fix this?
I had the same problem. I just reflashed with NVFlash for internal instead of the external.
You just have to place the roms in the internal memory instead of the external sdcard.
No clue on why it happens, but I hope this helps you out.
