phantom6294
Phone: OG Droid (obviously)
Current ROM: LGB v1.5 (but has happened across ROMs)
Current Recovery: ClockworkMod 2.5.0.1 (Pretty sure if happened on 2.5.0.0 but it's been a while)
Problem: Basically, on EVERY first attempt to boot into recovery, the SDCard does not mount. It doesn't matter if I try to 'reboot' into recovery, shut down the phone then boot (holding X) into recovery... EVERY first attempt results in the SDCard not being mounted and after a few seconds, the phone automatically reboots itself. If I catch this in time, I press and hold 'X' and get back into recovery on the reboot and the SDCard works fine.
My wife also has an OG Droid so I swapped SDCards with her. For a while that seemed to fix the problem. (I recently rooted her phone and noticed it did the same thing after flashing Clockworkmod Recovery, so it seems to be a SDCard problem versus phone problem) However, now my phone is once again fails to mount the SDCard on the first entry into recovery.
I've also tried reflashing the recovery as well as flashing to an alternate and then back to CWMR with no change.
So, anyone else had this kind of behavior? Am I destined to buy new SDCards??? Any other ideas?
