Help Cant move Home Icon
Xtreme00
So my phone went haywire today and switched my default homescreen. After the update when you go to edit and the multiple home screens appear there is a small house icon to corrospond with the main homescreen.
For the life of me i cant figure out how to get my old home screen to be my default again. I have tried adding multiple pages and nothing helps. Heck i cant even delete the home screen that it is defaulted to now.
Any help?
Thanks!
The center /odd number is always your home screen. you cna try moving the screens around but if that doesn't work, if you delete the other screens the only one left will be the home screen and you can customize it back the way you had it
If you use a 3rd-party launcher, not only is it far-easier to explicitly set your default home screen, but you get a myriad of additional features.
The Captivate FAQ has more info:
Customization - CapFAQ
