Help Cant play Pandora through bluetooth..
SpaceOut
The bluetooth I have is the Jawbone prime and its currently synced with my phone. I can talk to people perfectly fine with the bluetooth but when I open Pandora, it doesnt play the music through the bluetooth. Is the Eris compatible to do that or do i have a defective bluetooth or do i need to enable something? I simply cannot find the option to open bluetooth to access media. :confused: Help!
I'm having the same problem with my plantronics beatbox909. But then I put the adapter in the headphone jack and it worked, but I'd still like to get it without the adapter.. and yeah, calls worked for me as well. I'm thinking maybe its something to do with the Eris, not the bluetooth.
The Eris is compatible, it's your bluetooth that doesn't support it. You mentioned you had a Jawbone. Most bluetooth headsets aren't stereo. You must look for stereo bluetooth which has A2DP such as the Motorola S9 headsets etc.
O'Doyle is right. I have a Moto S9HD that works just fine with Pandora.
The why would my Sync in my Ford not work with Pandora over Bluetooth. It worked fine with the Blackberry I had? It also works fine with the main media player. (the car is a 2010, and was supposed to have the update from the factory)
i use to be able to play pandora and slacker over my plantronics voyager pro with my winmo tp2. cant get either one to work with my evo....
Jawbone Era plays all of my music on my Evo. Haven't played with an Eris, but I personally have never had a problem with the Jawbones. Had my Evo since April last year and had the Jawbone Icon since release. Once the Icon got the A2DP update, everything has worked perfectly.
Motorola S9-HD Stereo Headset on my T-Bolt - Not working with Pandora
Anyone else having the same issue? Phone features work ok on my S9-HD, but Pandora is not working. It was working fine on my old Blackberry.
Bummed...:(
