Root Cant reboot help!
I will preface this by saying that I am new to this. I rooted my phone with no problem, I was using rom manager trying out different things, I used the cyberclock and titanium backups. I tried the new cyanogen with a chevy01 overclock kernal and now it wont reboot.
Try loading up a few different kernels on your SD card and try flashing them like you did the Chevy Kernel and rebooting , eventually you should find one that will boot up . Not all kernels work the same on all Droids. Give that a sot it should work. Also if you used set CPU to adjust the CPU speed make sure you turn off any profiles you have set bsfore rebooting, sometimes when the CPU is clocked to low it cant boot up, I had same problem. Good Luck, let me know how you make out.
I used the power plus x on the keyboard and wiped it and rebooted to my root.
Did you revert back to your backup? Did it work? Also if you haven't already Download ROM manager ( paid version if you can afford it) from the Android market and flash clockwork recovery. That way you can reboot through ROM manager also.
I had rom manager, I 4got about the manual reboot, so thats what I did. Now I am trying to flash sourcery v1.0, but I dont know how to do that w/o rom manager lol.
Go to the market and download the free version and do it that way, im not sure if sorcery is on it or not
