RhinoCan
I have a Samsung Galaxy A5 (2017) bought new in 2017. A few weeks ago, I suddenly found myself unable to put the end of the charging cable into the charging port; the USB-C connector would not quite go onto the bit of circuit board in the charging port (sorry, I'm not sure of the vocabulary for that part of the phone.) I don't remember doing anything to physically damage the phone but the USB-C simply wouldn't seat properly after that no matter how firmly I pushed. (I did NOT want to break it entirely so I didn't force it.) I have two chargers and had the same issues with both chargers. I can't see any sign of anything wrong with the chargers: I'm nearly certain the problem is with the phone itself. I *think* the problem is that the bit of circuit board I need to attach to has moved slightly so that it is too far inside the phone to make proper contact.
Eventually, I determined that I could get a slow charge out of the phone by holding the connector in the connector port at a specific angle and pressure and this tided me over since then; I was even able to get the cable to stay connected while it charged overnight for the last few weeks.
Tonight though, I cannot get the cable to sit in the right place, even if I hold it myself and I simply can't sit up for the next several hours even if I want to. There is noisy construction that is happening very close by starting at the crack of dawn each morning and I'm already up too late now.
I don't know much about electronics but I'm wondering if this is even fixable. Perhaps if I could get the phone open, I could push the bit of circuit board I need to engage with back into its proper position and charge it normally. Or is that wishful thinking?
COVID has really messed with my finances and I have no money to spend for repairs, let alone another phone. I've been really happy with this phone and would love to figure out a solution to this problem. Any suggestions would be very gratefully received!!
