Root Cant sbf dx2!!! Need help please
Nick888
hey guys, i need to sbf my droid x2 because i had recently installed a metamorph icon and my status bar went away. i need to sbf (unless yu guys know a alternate solution_ my droid. i am running OSX but i have Windows xp service pack 3 running in VMware fusion (virtual machine). i installed the 32bit drivers and RSD but when i load the sbf file into RSD and put my phone into RSD mode, i get a fail after creating system image. i have tried MANY sbf files and nothing works...i need help guys!!!!!!! thank you for your time,
-Nick
i just SBF'd last saturday... went fine.
used this filename to SBF back to 2.3.4
VRZ_MB870_4.5.1A-DTN-117-15_1FF_01.sbf.gz
Also, what version of RSD Lite are you using? I have always used version 5.3.1 and never run into any issues, I have seen other users use a later version and run into issues.
hey man thanks for responding, im running the newest which is 5.6. should i try somthing else? if you can link me to another version that would be great!
hey guys just wanted to let you know all is fixed!!!!!!!!! i appreciate the help and all i did was try and reflash it over and over..thanks!
