Help Can't send MMS on S2? Bell
godoffire
Hey I just recently got the S2. Absolutely love it!
But i can't send MMS. Whenever i add a picture to a message and send it. It tells me there is no service and the picture will send when service is available. When I do have service.
Any ideas?
Carrier= Bell
Go into settings. Then wireless and network, mobile network, then access point names. Check that the access point you are using has the following three options set.
MMSC
MMS proxy
MMS Port
If these aren't set that will be your problem. Not sure what they are supposed to be for bell so if they're not set do a google search to find out or contact bell. Once these have been set change the APN type to internet+ MMS
Was having the same trouble with my Samsung Galaxy S2, yet my hubby was able to receive picture text messages with no issue. Came to find out that the phones firewall "LOOKOUT" that I turned on was the culprit! I went into LOOKOUT and unchecked all the boxes to disable it and voila! No more issues. I am now able to receive picture texts on Wi-Fi without issue. Deb:)
