Help Can't send or receive MMS
Ok so from what I've read in this forum (yes, I've tried), I need to do something to my APN settings to get my MMS to work. My questions are:
1) How do I change the settings? I only have one (Telus SP) and it's locked. I can't change anything whatsoever
2) What are the right settings supposed to be?
3) Does the phone need to be "rooted"? I don't even really know what that entails, I just know you need to root a phone before you can do some things.
Any help would be appreciated. Telus gave me the good old "take your battery out, and put it back in" advice. That didn't solve it, so they started a ticket. I figured I'd have much better luck here.
Thanks in advance!
ps- In case it's important...I have 2.2 installed on my phone
Have you tried creating a new APN using the Telus settings?
Go into APN's so that you can see yours in the list, press the menu button and select 'New APN', enter the settings for your provider. Then menu > save. See if you can select your new APN, then back key, power off and restart your phone.
Go back into APN's and check that your new APN is selected.
Someone has listed the Telus settings here.
http://androidforums.com/hero-support-troubleshooting/45005-mobile-network-apn-settings.html
