Help Can't send/receive MMS
gripweed
I need some help.
I turned my data off for a day to test battery life and see how long I could do. Turned data back on and now I can't send MMS.
I deleted the cache last night and then it worked. Turned the phone on today and now I can't send MMS again.
I checked all the settings, I don't see anything that's changed. All I originally did was toggle data to off then back on and then this happened.
Anyone have a suggestion?
Thanks
stupid question. But are you in "good" coverage area or a fringe area?
Also if you dont' mind i would like to move this to the VZW specific section. Thanks.
Sure, move wherever. I didn't know where to put it, figured maybe it was something specific with ICS at the least.
Also, yes, in a good area, full bars.
Yeah i think it's more related to the VZW version tho. No worries.
Ok what method did you use to turn your data off and then turn it back on?
