Root cant send/recieve mms messages
ok i got this phone from my brother its a lg esteem ms910 4g and it seems he flashed a custom rom from what i can see its DoVeRTeD ROM v1.4 sw.version ms910ZVD um it is rooted .so my problem is i cant send mms messages .. or recieve any ..i can send reg text and recieve reg text msg ..when i try to send mms it jus says sending but never sends ..and if i get a mms message i can recieve it but when i click on download it jus doesnt open ..can anybody help thanx.
you know what i just restored to a earlier backup same rom and there going through. so ...so if 4g isnt enabled they wont go through ? alright thanx ..
and i noticed somehow i dont know how but my bro apparently deleted his metro stock rom. cuz after i did a hard reset .it started up with some other rom he had i thing black plague. .theres no stock rom on the internal..otherwise i would jus put it to metro stock.. and from what ive been reading you gotta do all kinds of shit to get it back to that .so i will jusleave it ..
You don't have to do anything crazy to return to stock, it's very easy.
check this guide, it may help.
http://androidforums.com/esteem-all-things-root/671585-return-stock-zvd-super-easy.html
you know what i actually tried that when i saw that i thought finally just install the zip and its done.. well i followed the directions and when i clicked on restore it started saying installing update then it aborted installation aborted.. no explanation why. and i also noticed something. the directions said to put file in the removeable disk clockworkmod,backups. well when i go to restore it shows all my restore points but the zvd file isnt there. so i went to chhose zip from sdcard. went to clkwrkmod bckup and there it was along with my restore points..so unless im doing something wrong ..
Yes. You put it into the clockworkmod backup folder only after you have unziped it. That's the only way you will see it in recovery from the restore option.
