this is what alogcat tells me at a filter level of warning....
W/InputManagerService( 1029): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@45b05f90
W/KeyCharacterMap( 7029): Can't open keycharmap file
W/KeyCharacterMap( 7029): Error loading keycharmap file '/system/usr/keychars/qtouch-touchscreen.kcm.bin'. hw.keyboards.65538.devname='qtouch-touchscreen'
W/KeyCharacterMap( 7029): Using default keymap: /system/usr/keychars/qwerty.kcm.bin
W/dalvikvm( 7029): threadid=3: thread exiting with uncaught exception (group=0x4001b190)
E/AndroidRuntime( 7029): Uncaught handler: thread main exiting due to uncaught exception
E/AndroidRuntime( 7029): android.content.ActivityNotFoundException: Unable to find explicit activity class {com.android.soundrecorder/com.android.soundrecorder.SoundRecorder}; have you declared this activity in your AndroidManifest.xml?
E/AndroidRuntime( 7029): at android.app.Instrumentation.checkStartActivityResult(Instrumentation.java:1404)
E/AndroidRuntime( 7029): at android.app.Instrumentation.execStartActivity(Instrumentation.java:1378)
E/AndroidRuntime( 7029): at android.app.Activity.startActivityForResult(Activity.java:2749)
E/AndroidRuntime( 7029): at com.android.mms.ui.ComposeMessageActivity.startActivityForResult(ComposeMessageActivity.java:435)
E/AndroidRuntime( 7029): at com.android.mms.ui.MessageUtils.recordSound(MessageUtils.java:500)
E/AndroidRuntime( 7029): at com.android.mms.ui.ComposeMessageActivity.addAttachment(ComposeMessageActivity.java:2282)
E/AndroidRuntime( 7029): at com.android.mms.ui.ComposeMessageActivity.access$4400(ComposeMessageActivity.java:153)
E/AndroidRuntime( 7029): at com.android.mms.ui.ComposeMessageActivity$16.onClick(ComposeMessageActivity.java:2305)
E/AndroidRuntime( 7029): at com.android.internal.app.AlertController$AlertParams$3.onItemClick(AlertController.java:884)
E/AndroidRuntime( 7029): at android.widget.AdapterView.performItemClick(AdapterView.java:284)
E/AndroidRuntime( 7029): at android.widget.ListView.performItemClick(ListView.java:3285)
E/AndroidRuntime( 7029): at android.widget.AbsListView$PerformClick.run(AbsListView.java:1640)
E/AndroidRuntime( 7029): at android.os.Handler.handleCallback(Handler.java:587)
E/AndroidRuntime( 7029): at android.os.Handler.dispatchMessage(Handler.java:92)
E/AndroidRuntime( 7029): at android.os.Looper.loop(Looper.java:123)
E/AndroidRuntime( 7029): at android.app.ActivityThread.main(ActivityThread.java:4363)
E/AndroidRuntime( 7029): at java.lang.reflect.Method.invokeNative(Native Method)
E/AndroidRuntime( 7029): at java.lang.reflect.Method.invoke(Method.java:521)
E/AndroidRuntime( 7029): at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:860)
E/AndroidRuntime( 7029): at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:618)
E/AndroidRuntime( 7029): at dalvik.system.NativeStart.main(Native Method)
W/InputManagerService( 1029): Got RemoteException sending setActive(false) notification to pid 7029 uid 10019
W/InputManagerService( 1029): Starting input on non-focused client com.android.internal.view.IInputMethodClient$Stub$Proxy@458ddfc0 (uid=10019 pid=7148)
W/InputManagerService( 1029): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@459ff658
W/InputManagerService( 1029): Window already focused, ignoring focus gain of: com.android.internal.view.IInputMethodClient$Stub$Proxy@45abc680
and at a filter of error it says this. not sure if it is still all for the messenger though. nothing fatal btw.
E/webcoreglue( 6982): The real object has been deleted
