Root cant send texts liquid 3.1
So I am having trouble sending texts. I can receive texts fine and can send text using google voice but would like to use the native app. any help would be appreciated.
This same thing was happening to me..at first a reboot fixed it, but eventually it got to the point where all my data stopped working..hopefully this doesn't happen to you. Do me a favor and check your baseband for me and see if that says what it's supposed to according to your current radio.
baseband is 1.39.00.0627r
how do I check if that baseband is correct? should I try an updated radio? I didnt flash a new one when I moved to this rom from stock rooted.
i checked the md5 sum before I installed it and it was correct. I could try a reflash but was hoping to avoid that.
