Hey guys. thank you all for your on going support and helpful advice I ran that command and it says the bootloader is unlocked, thats soo weird as I cant install supersu on my device or root my device. heres the code listed below.
(bootloader) max-download-size: 0x8000000
(bootloader) partition-size:: 1500000
(bootloader) partition-type:: <null>
(bootloader) partition-size:fat: 2b00000
(bootloader) partition-type:fat: fat
(bootloader) partition-size:userdata: 32000000
(bootloader) partition-type:userdata: ext4
(bootloader) partition-size:cache: 8000000
(bootloader) partition-type:cache: ext4
(bootloader) partition-size:system: 54000000
(bootloader) partition-type:system: ext4
(bootloader) partition-size:expdb: a00000
(bootloader) partition-type:expdb: raw data
(bootloader) partition-size:custom: 800000
(bootloader) partition-type:custom: ext4
(bootloader) partition-size:ebr2: 80000
(bootloader) partition-type:ebr2: raw data
(bootloader) partition-size:logo: 300000
(bootloader) partition-type:logo: raw data
(bootloader) partition-size:frp: 100000
(bootloader) partition-type:frp: raw data
(bootloader) partition-size:misc: 80000
(bootloader) partition-type:misc: raw data
(bootloader) partition-size:sec_ro: 800000
(bootloader) partition-type:sec_ro: raw data
(bootloader) partition-size:recovery: 600000
(bootloader) partition-type:recovery: raw data
(bootloader) partition-size:boot: 600000
(bootloader) partition-type:boot: raw data
(bootloader) partition-size:uboot: 60000
(bootloader) partition-type:uboot: raw data
(bootloader) partition-size:seccfg: 20000
(bootloader) partition-type:seccfg: raw data
rotect_s: a00000
rotect_s: ext4
rotect_f: a00000
rotect_f: ext4
(bootloader) partition-size:nvram: 500000
(bootloader) partition-type:nvram: raw data
ro_info: 300000
ro_info: raw data
(bootloader) partition-size:ebr1: 80000
(bootloader) partition-type:ebr1: raw data
(bootloader) partition-size:mbr: 80000
(bootloader) partition-type:mbr: raw data
reloader: 1000000
reloader: raw data
(bootloader) off-mode-charge: 1
(bootloader) warranty: no
(bootloader) unlocked: yes
(bootloader) secure: no
(bootloader) kernel: lk
(bootloader) product: PIXI4_35
(bootloader) version: 0.5
all: Done!!
finished. total time: 0.184s
Also not sure if I mentioned it but in dev settings theres an option to allow OEM to be unlocked, which ive turned on as previously when trying to unlock the bootloader it said operation not allowed. After researching this I found out that turning on that setting allow oem to be unlocked. it gets me one step closer towards solving the puzzle.
I remember a while ago I got into the phone rooting modding situation never had any issues towards the bootloader at all I was running a Samsung Galaxy S4 rooted and running CM11 with no issues.
I do have another device Ive borrowed from a mate called ZTE blade I will see how I go with unlocking that bootloader just curious as to what the outcome will be.
