Root Cant Unroot My Evo!! Data Not Working!!!
I rooted my evo a couple of weeks ago and flashed the Miui rom and up untill yesterday it was working fine. I hav searched all over the internet lookiing for a way to unroot it and all my attempts have been unsuccessful..
Can somebody please help me with my situation??!!! :(:confused:
Welcome to the forums :). So, what state is your phone in, now?
1) Are you able to get to hboot, recovery, and boot up, or are one or more of those things not working now?
2) What was your rooting method?
3) What is your hboot version?
4) What have you actually tried so far?
I'm able to get into hboot recovery and boot up
i used unrevoked 3
The newest hboot version
ive tried the ruu_supersonic method, i tried updating the using 3.70 official update, i tried to reroot it again, the unrevoked-forever pc36img.zip way.........nothing is working:(
i used unrevoked 3
Ok, do you currently have S-ON or S-OFF when you got hboot?
Ok, not sure what PC36IMG.zip files you've tried, but this is the correct one. Download it, rename it to PC36IMG.zip, exactly. Make sure you don't accidentally name it something like PC36IMG.zip.zip (as windows hides extensions by default). Also, make sure you don't unzip it or anything. Copy it to the root of your sdcard (top level, not in any folders). Turn the phone off, then turn it back on while pressing and holding volume down. That will take you to hboot, where it will scan for the file. Assuming it does, it will prompt you to flash it. That should unroot the phone the rest of the way (remove custom ROM and and custom recovery). Let me know if that doesn't work.
