Reminds me of trying to install Windows ME.
Windows ME had issues with its install program. How much space was reported as being required varied depending not on what was to be installed, but on how much space was available. What it thought was required was different than what was required. So it was sometimes difficult to install Windows ME.
This is similar. Here what it apparently (and presumably) needs is less than what it has available, but it thinks it needs even more. Same result though--you can't install.
We are not talking about computers here.
That's an option. Another would be to free up unused space on your sd by copying the contents in their entirety onto your computer, reformating your sd card, either in the phone or in your computer (as fat32), and then recopying everything in its entirety back to the sd. Due to the way the Android OS handles file/folder deletes, they are not really deleted, just marked as available. This can confuse space estimates, like you're seeing. This problem is fixed BTW in Jelly Bean 4.3.Caches of apps can take a lot of storage.
Try a cache cleaner like 'App Cache Cleaner'.
It might free enough storage for your update![]()
