I'm using quickpic too and haven't had this problem. I'm also using handcent. Are you using the stock text app?
If you want to try the stock viewer, I'm assuming you set quickpic as your default, from the mainscreen tap menu-settings-applications-manage-look for quickpic then tap it and clear default.
