Root Can't write to /system/etc ????
IPvFletch
Here's a weird one, I can't copy files to /system/etc - I'm getting "out of memory" errors from adb push and "cannot allocate memory" if I try using adb shell and try to "cp" the file to /system/etc from /data/... WTF?
:confused:
Freaky, I just did "adb push filename /system/etc" from Recovery and then I looked and /system/etc is a file. I'm like NOOOOOOOOOOOOOOO!!!
Then I rebooted and all is well. Then I went back to Recovery and looked. It's just a vfs made on the fly, and there is no /system/etc just a /system/bin so me pushing a file merely made a file there, it isn't the real /system/etc LOL that was scary!!
So seriously, any ideas on writing to /system/etc while Android is running? I did the unrEVOked 3.2.1 root a while back, I left S=ON just FYI..
No it is RW but it is read only some how.
I just re-ran unrevoked3 and this time did S-OFF nand unlock. Now it works and I can copy it over using adb push or like you said via teminal. I'm happy. :]
Oh, right, I should have suggested that. Glad you got it working.
