I've had my captivate for about 4 months and, despite the initial dud that I exchanged, am actually pretty happy so let me start by saying thanks for all the great info on this site. I learned a lot when I first bought it and quickly went back to AT&T when I had the random shutdown issues on the first to start fresh.
I just installed mybackuppro after having the trial version on my phone and after the first back up, am having issues. The phone is not rooted but I do use LaunderPro. The issue is that all of my widgets stopped working:
Beautiful Widget homewidget has a working circle and says "loading" constantly
Facebook works but NYT, ScoreCenter, DoggCatcher, Extended Controls, Flightview and a stocks program all show up with various issues- either not starting, or mostly stuck on "Loading data". None of them will even open their respective apps
Also, none will let me update (ie- adding flights to flightview) and all work as apps when opened through the tray (I can open doggcatcher and it works like usual but widget remains blank)
I've tried removing and adding the widgets again and I've tried reloading all the data from MyBackUp but nothing changes. Some problems get better or worse after restarts.
Did I do something wrong? Should I remove Launcher pro or mybackup and start over on one of them?
Thanks again!
Thanks again!
