Help Capacitive function lost Ideos 8150
lrollo
My phone responds to the off/on switch and lights up, but does not respond to the swipe action.
The capacitive function was faulty a few times on the return button and then failed completely.
I tried taking the battery out for a few hours and storing it, but still no capacitive function.
The battery has been fully charged in all circumstances.
Is there anything I can do to recover functionality ?
:confused:
Hi Irollo, Have you tried cleaning the screen? A film can build up on the screen and you need to clean with non-solvent cleaners.
If it still doesn't respond - I would first do a Factory Reset.
From the Huawei User Manual:
12.8 Resetting Your Mobile Phone
12.8.1 Backing Up My Data
You can use your Google account to back up your mobile phone
