gmariconda
I traded in my HTC aria for the Samsung Captivate about a week ago and I am having problems with my pop email. On the HTC Aria all of my 3 pop accounts worked perfectly and i never had an issue. On the captivate it just doesn't work. I have to manually go into each account for it to send/receive. it does not check every 15 minutes like i have it set to.
it did seem to work the first day then stopped. i have factory reset the phone twice and reset up the mail accounts but it just doesnt auto check on its own.
if both the HTC and Samsung are running android 2.1 why would one work and not the other.
do i have any options? i downloaded K9 mail to try that but i would rather use the default app if i could.
thanks.
thanks.
