D
Deleted User
Guest
After days of configuration and test, I finally made Kies work with outlook 2010 on Win 7 (x64).
Phone: Samsung Galaxy S Captivate (SGH-i896)
OS: Froyo
Carrier: Rogers
First I need to thank everyone who posted their experiences which benefit me a lot.
Here is my experience:
OS: Froyo
Carrier: Rogers
- Get the latest version of Kies from Samsung Europe or Asia site. Check updates and install if exists.
- Find Kies.exe in C:\Program Files (x86)\Samsung\Kies , right click it and select properties. In compatibility Tab, choose Win XP (sp3), and Choose “Run this program as administrator”.
- Do the same thing for KiesTrayAgent.exe.
- Make sure drivers for your captivate are correctly installed.If you are not sure. Try install drivers again from Kies ->Tools
- Connect your Captivate to USB and choose Samsung Kies mode.
- If you have problem sync Contacts, try to run SCANPST.EXE from your outlook program folder.
- Most important of all, (I figured this all by myself), if your Captivate is rooted and you installed OCLF lagfix V2.2+, you won’t have any chance to make Kies to work with your phone. So, remove OCLF lagfix V2.2, you will find everything works fine now.
