steaksauce
Hey folks. Just upgraded to a Samsung Captivate from a Blackberry Bold 9000. I love the new phone! But with one major problem. It takes so long to charge! On my Bold, it probably took 40 mins to an hour to fully charge from say 10% life. The Captivate looks to be taking 3 to 4 hours. Not acceptable. If I'm on the run all of the time or forget to charge my phone at night, then I'm screwed!
I am using the OEM USB wall charger.
Has anyone used a different wall charger that improved the charging times? (I've heard one report on the Net that someone used a Radioshack one where .1 amps are used instead of OEM's .07 amps.)
I know turning off the phone or apps makes it charge faster but that's not the solution I'm looking for.
TIA
THREAD SUMMARY:
1. Captivate does take a few hours to charge
2. Charges faster connected to the wall than to a computer via USB
3. Get a extra battery/charger set
4. Batteries for Fascinate and Captivate do not work with eachother
5. Cheapest OEM set: http://www.cellularaccessory.com/et-chgpknvgsta.html
6. Cheap Chinese battery (2) and charger sets are available for around $10 on Ebay
TIA
THREAD SUMMARY:
