Captivate WallPaper
I have realized that the captivate wont allow you to put the whole picture as the wallpaper :( it is really buggin me any suggestions . need help:confused:
Huh yes it does. I use whole images a lot of times.
Pictures taken with the camera or images in the gallery, most of them, need to be cropped so it does not let you use the entire image. I found it rather annoying but I use the zedge app and I can use most of the wallpapers there with the whole image.
I have the same problem. I tried to use some photos I took with my camera (not the phone) and tried a few different resolutions, including what is supposed to be native to the phone and it only allows me to use the top half of the photo, and then when I am on the home screen, it shows even less.
Download live wallpapers from the market! Or hd still wallpapers from Flikie or Zedge. I don't think you'd ever use photos you've taken on your phone's camera again as wallpaper. There's also the option of using the native picture frame widget, which is what I do.
I believe the reason it shows less on the home screen is because Touchwiz has wallpaper scrolling enabled so the wallpaper stretches across all your home screens. I dont think this can be turned off on TW but if you are using a diff launcher I'm pretty sure it can be disabled.
