I have looked at several other threads on the matter, but none seem to be 100% identical, not have any of the fixes worked for me.
My Captivate USED to work fine on WiFi. I put the Unofficial Froyo on it as soon as I got it from AT&T. It has worked fine for a long time. Until now. WiFi will not connect to anything, ever. As this did not occur when I installed the Unofficial Froyo, and it worked for a very long time afterwards, I doubt his is related. I just wanted to mention it for the sake of being thorough.
Says "Obtaining IP address from..." then "Disabled"
I have 4 other computers that connect to the WiFi without issue. In spite of this, I have tried the following:
I have hard reset my router to defaults. All other computers connected with no trouble. Captivate would not.
I disabled all security on WiFi. All other computers connected with no trouble. Captivate would not.
I had changed all WEP/WPA/WPA2/No Security and SSID in random combinations. I have changed channels as well. Every time, all computers connected with no issue. Captivate would not.
Captivate will "see" any WiFi network, it will identify Open or security type(s). It will display signal strength. I can tel it to "forget" but this has no effect.
When told to connect, it will say "Obtaining IP address from..." and then after about 30 seconds, "Disabled."
I have Rebooted many, many times. I have removed SIM/SD, etc. I've done everything I can do to it. It will not connect to any WiFi anywhere, ever.
WiFi Router works flawlessly with any other device regardless of Security/SSID/Channel.
If I had a way to wipe the Network Data via Console/Command Prompt, would that matter? I'm not a noob. I've been running Gentoo Linux for nigh on a decade. Clearly, there is something wrong here. I need a way to get at the problem.
