Help Captivate Won't Mount on PC via USB
barr08
Member
Hey all,
The first couple of times I connected my new Captivate to my PC via USB, it worked fine. I was given the notification to mount and view my files, and I was able to access everything.
This morning, I plugged my phone in, and told it to mount in the notifications, but it did not appear on my PC. When I unplugged it and tried it again, it was not recognized at all as a USB drive.
Notes:
-I am using the "internal SD card". I have no external microSD to use at the moment.
-The phone charges when plugged into the computer, but does not mount.
-EDIT: I have tried reinstalling the USB drivers via links found on this forum.
Any help on this would be great! Thanks!
So I went into the USB settings under Applications and turned off automount. For some reason, it works fine when I manually tell it to go into USB mode every time I plug it into the PC, but it doesn't work correctly when I tell it to mount automatically. Weird.
Anyways, seems like this isn't that much of an issue any more.
