Help Captivate + Zagg(tm) Invisible Shield (tm) + ...
saintdanbert
I have a Zagg shield on my Captivate. In general, I know these to work and work well on a variety of phones. In addition, Zagg stands behind their shields very well.
That said, I'm having troubles pressing the "hard buttons" at the bottom of the screen: Menu -- Home -- Return -- Search. Does anyone else have this sort of trouble with the Zagg and Captivate?
My symptoms include:
1. press anywhere launches search
2. button press requires extra effort for button to register; when it does
see #1.
3. button press causes activation of whatever is above the button field
at the bottom of the display area
I've posted a question with Zagg support. When I get that answer, I'll follow-up here. Until then ...
Hoping for advice,
~~~ 0;-Dan
I had a zagg on my phone and I was having the exact problems with the buttons you are stating. I would push back and I would get search. Ditto for the home button. And I had to push rather hard. I decided I was tired of the look of the zagg, so I took the thing off last night. And what do you know....the buttons work *perfectly*. I barely have to tap them and there are no instances of getting search a hundred times. I am so happy I took it off.
I have Zagg shield too, and have noticed a difference, how do you get it off?? I have emailed the company and no response. I hope it don't leave marks on my new captivate!!
When I removed my zagg shield, it just peeled right off. Very easily and no sticky residue behind. Much easier than I expected. And what a difference when it was off!
Just took off my Zagg Shield, couldn't be any happier to have it off, although I do feel bad about the money wasted. Oh well.
I just put the Zagg on my phone, because the other one i had i wasnt happy with what it did to the images on the screen. I was have severe issues also with the back button. I have had no problems with the Zagg. I have found that if you are not right on top of the back button it will bring up the search. Just use light taps to get it to work
I use "denatured" alcohol to clean things like this.
See Denatured alcohol - Wikipedia, the free encyclopedia
(That is not "rubbing" or other "medical" alcohol. Those tend to have additives like lanolin for soothing of the skin.)
I dab a bit onto a cotton swab or ball and wipe. Cuts all sorts of guk without
damage or scratches.
~~~ 0;-Dan
If any screen protector film or phone glove (case, cover) limits the edge of the screen to move slightly around the hard buttons -- Menu + Home + Back + Search -- the buttons either fail to work or work poorly.
Cheers,
~~~ 0;-Dan
