Car Charger...
PatrickD88
Can anyone recommend a brand name of car charger you like or hate for the Intercept? My battery drains pretty quick. (I listen to a lot of podcasts while driving.)
Thanks.
I just got a cheap one off amazon for like .49
No idea what brand it is, but it works like a charm. Especially for the price lol
Hm... If your [car] doesn't let you listen to podcasted directly on your radio, ever looked into an iTrip FM Transmitter? The one I've got has a USB port on it as well as your standard headphone jack. I've gotten it specifically to use for both my (then) BlackBerry and my iPod.
Check about halfway down on this page and you should see one for 89 cents, shipped. It doesn't include the cable but you can use the same cable that came with your phone.
They are a reputable dealer of this sort of stuff. I buy from them all the time. You need to apply the coupon code shown for the item to get the 89 cent rate.
