Car Charger
clok1966
When I hook my droid up to my Car charger (ebay) or my old car charger (its the same USB connection) my DROID wont charge. In fact it only charges when hooked to a PC via USB or the AC power to USB that came with it (my generic AC to usb wont work either). Is versizon doing the same old crap and making it so aftermarket acc wont work?
I wish I knew, My old phone was a DARE also and its old charger wont charge my DROID. I picked one up off Ebay, no good. I went and picked up a new motorala one and it works. Maybe I'm just unlucky it seems as others are using generic ones. Very strange.
It may have to do with the mA output of the charger. If you look at the sticker on the Moto OEM charger, you see the output is 5.1V & 850mA. Most USB-host ports only supply around 500mA, and a generic usb or car charger may supply even less.
On my old Q9c, if the battery got completely drained I couldn't charge it via USB, I had to use the OEM wall charger; I'm pretty sure the Droid is the same. Just a side effect of being a power-hungry device, I think.
