Help Car charging not working since Froyo
BBock727
Member
So I have been using the cigarette light adapter and separate 1 ft cable, both of which i got from monoprice. They worked fine before i got froyo. Since i got froyo, when i plug it in, the red/orange light just blinks on and off and my screen turns on and off.
Not sure if anyone else is having this problem but i have to be able to charge!!
A) try a different usb cable.
B) try a different usb source with the 1' cable.
It sounds like your charger is flickering on/off which would explain why the charging light and screen are blinking. Could just be a crappy connection or could be a bad charger or bad cable.
Sounds like the cord works. Also sounds like your phone charges fine with the computer. That points at a bum car charger. Try charging something else with the charger and cable. Whats the amp rating of the car charger?
