I'm using EB01 leak with SuperClean 2.0.
i Just picked up the samsung car dock. very nice that you can play through the usb.
one thing, i usually use Pandora. is there any way to put a Pandora icon in the car cradle app, or have the music icon open pandora?
I'm not getting any FC's, but i do have no activities found for music, and i was wondering how to fix that.
what you need to do is open up the car cradle, and hit the speaker icon to turn sound off, then it will play through the usb. so since i use pandora, i have to open the cradle app, then hit home, then click on my pandora widget. now if i can only configure a music activity.
i have it set to mass storage. i'm going to try media player. i have bluetooth in the car, so my phone conversations go through there.Eppo120,
Have you tried to use the phone with the USB enabled? Do phone conversations go through the speakers and are people able to hear you during the conversations?
Speed...
If the usb media player setting does what i think it would. is there a way to have Pandora load when i put the phone in the dock instead of Car cradle?
I saw there were a few that you can use. the one i tried is Custom car home. i only played with it for a minute or two, i was on my way back from work. it didnt play out of the USB so i just went back to what i knew worked. hopefully this setting works.
Very cool!
thank you for your help. i was reading that thread, and noticed that you went in and decompiled the program. i would definitly like to get into this a lot deeper, that way i could make these types of modifications on my own.
would you be able to give me a good place to start? or what do you use to decompile the programs?
thanks
