car dock problem
crcjetty
i have a genuine Samsung car dock for my S2. the issue i have is that when ever i put my phone in & connect it, the voice talk app starts. the same one that starts when you double tap the home button. is there a way to stop this?
I have the same problem too. Would be interesting to find out.
Me too - and i can't find anything in the settings to switch it off so i think it's designed that way (perhaps a safety thing?).
If there is a way (app developer, anyone? :) ) would be great to know as it's annoying as hell.
Install Ulysses Speedometer, when you plug in the car dock you get the option to make it the default action. If you use a bluetooth headset pressing the button then puts you into the 'what would you like to do' prompt (which I have to say works well enough for me). I subsequently upgraded to the pro version, all of
Are there any other apps that allow you to change that default action? I am using extreme virtual assistant on my S2 and would like to have Eva's car mode activate when I dock
Hi,
I'm happy that you liked my recommendation, I think it's a programming function to make the program aware of the 'car dock' mode. I just had a look in the apps on my S2 and against Ulysses it says 'you've chosen to launch this app by default for some actions' under 'launch by default' the only option is 'clear defaults'........ maybe you could try asking the developer of EVA to add 'car dock' detection.
Andrew
