Root Car dock won't install
Indrid Cold
Anyone have this problem?...
I deleted bloat awhile back and found the link to download and re-install all of the bloat I had removed. (Droid X Default Applications - ChadHaney.com) I followed the directions and put BOTH the .apk and the .odex in the system/app folder. It worked flawlessly except for car dock.
All of the apps re-installed except this one. I get just a simple message stating that it did not install. My only option is to click "done"
Anyone know where I can get a copy of the car dock that DOES install? Preferably the OEM...Thanks
I personally use an app called carhome. It's better than the stock car dock with more options. You can find it at the market. I can't remember but I believe they have the app for free but to get all the functionality you have to buy the license key.
First of all, thank you sir for answering me. You appear to be the only one who will. Thank you!
But what I'm really looking to do is just get everything back to original "out of the box" condition for future OTAs.
Titanium isn't recognizing everything. All apps are in the correct folder, (system/app) but not all are actually installed. Titanium does NOT show the ones that are not installed.
Could this be a problem for gingerbread? I don't know. I would really rather not have to SBF to stock. I know exactly what bloat I need. I just can't find the ones that WILL install. Any help would be greatly appreciated.
I'm not sure who said this but..."Let this be a lesson boys and girls." NEVER DELETE BLOAT. Don't be a dumbass like me. Freeze it instead...*sigh*
Since my original post I found a few more in the System App Remover app. These are the ones I can't get to reinstall. They showed up in the system/app folder when I restored them, but they won't actually reinstall. Again, I really don't give a damn about the apps themselves. (freaking bloat) I'm just trying to get back to stock "out of the box" condition.
Rather than driving yourself crazy just sbf back to stock using rsdlite. after you do that go into your stock recovery and wipe your data and dalvic caches. that will give you the "out of the box" your looking for.
Don't forget to activate your phone when your done or you will be wondering why you can't make/receive calls....lol.
