Car mount for extended battery
guttyla
Anyone know a good one that fits bionic with or without hard case...looking for one on this cyber monday
The car mount that is made for the BIONIC works with both regular and extended battery. However, the mount is very short, sometimes making it get in the way if you're taking pictures / making video.
The old Droid car mount and Droid 2 car mount's had an extension that swiveled in 2 directions only, but the extension puts it much further out from the base, and it looks like it will allow you to take pics without having the base get in the picture. The actual phone holder from the BIONIC car mount fits the ball joint on both older mounts as well, a major plus.
Depends upon the case - I know it works with the stock VZW Shell / holster combination, and I've heard it works with some others.
But you didn't say anything about a case in the fist post - you might want to add that in there as well, so we know exactly what you're looking for - for example, I don't know if there is a car mount that works with the BIONIC in an Otterbox (there should be, but they are going to be more of the generic type car mounts).
It works with Motorola's gel shell, which is pretty thick. I needed to remove the insert of the car port first.
