Car Use: FM Adapter / Charger ?
Sonic77
Anyone have any suggestions on how best to use the Tab in the car.
Need an FM adapter and a power charger, any suggestions?
Buy the Car Dock from Samsung. It charges the Tab off 12VDC and it keeps the screen on while charging in the dock. Makes a great GPS using voice prompts. I use Microsoft Sync to connect the Tab to my Ford Flex sound system. Slacker Radio Sounds awesome. You should be able to plug any FM modulator with a 3.5mm plug into the Tab.
Your setup sounds great.
Without built in bluetooth in my auto,
was hoping to find something that would charge
and have a fm output with just one cable?
Anyone try the Bluetooth to FM car adapters on ebay?
