CriticalCritic
Android Expert
1. Can anyone recommend a good windshield mount for this phone? I prefer to have something that holds it horizontally (FYI I will be using the seido LE case if that makes a difference).
2. Does anyone know of a way to auto (or manually) rotate the existing desktop without installing a whole new desktop software? I like my phone as it is, and when I put it in the car mount I want it to rotate my desktop... without getting rid of the stock Sense setup. Does anyone know of a program that can enable this? I assume that it is a possible because my old Samsung Moment would rotate the stock homescreen when the keyboard was pulled out, and only when the keyboard was pulled out.
3. Does anyone know if there is a difference in power between charging through a USB cable via computer connection, or charging through a USB cable via car outlet?
4. What is the most efficient way to do speech to text for SMS messaging? I haven't really gotten into exploring it yet, but I am curious if it's simple enough to do while behind the wheel.
5. Just curious what are people using as a SMS text to speech app?
