Desertrobot
Hi everyone, I just had the pleasure of finally receiving my HTC One M8, so far I bought two cheap cases, a rugged one and a slim clear one.
One of the main things I wanted to do with this phone was use the IR blaster, however, I dislike the slimness of the clear case (which is clear over the IR blaster, but doesn't provide any protection), but then I can't use the IR if I use the rugged case.
TL;DR
So I'm looking for a case which is rugged, and has a clear window over the IR blaster, however I don't want the window to be a hole, I want it to be clear plastic so the power button is still protected. So far I only have the Supacase Unicorn Beetle in mind, which has clear plastic over the IR and is also rugged, but I'm not too crazy about the design. Are there any other cases like this I can look at?
THANK YOU
TL;DR
THANK YOU
