Case free
Banished Angel
I got a case for my Evo and it is an absolute pain to get off! I have the HTC dock for the phone, but of course the phone doesn't fit with the case on. It's so much of a pain that I don't even like to take it off at night to use the dock. I'm not worried so much about dropping my phone as I am about the camera getting scratched. Can anyone who doesn't use a case tell me if that is something I should be worried about?
I haven't used a case since the phone came out and not a single scratch on the screen or the camera. Other then the scratches around aluminum screen housing
The screen is gorilla glass so I don't bother with a screen protector. I'm not sure if the glass around the camera is gorilla glass or not. I just don't like the fact that the camera touches whatever I set the phone on and the phone isn't raised around it at all.
Hope this helps http://www.pocketables.com/2011/07/htc-responds-to-concerns-about-htc-evo-3d-camera-lens-cover-vulnerability.html
I had the same concerns as the OP, but I kind of figured this on my own. I mean, HTC builds a LOT of great phones, they aren't some random company that pooped out one 3D phone. lots of R&D goes into making these pretty durable. I run without a case. But I'm also a pretty careful person, most of the phones I owned in the last 4 years looked the same when I sold them as when I got them. Never had a case on any of them.
+1 for quality products. The Evo just feels so much sleeker without a case. Now here's to hoping I never have butter fingers.
I bought the Otter Box Commuter series case. It adds very little bulk but protects the phone well. It's already been dropped tested.
i have to use a case because i hate smudging the camera lenses with my finger when i'm holding the phone, and because of the rare drop (no one's perfect). I got a tpu case for ~1.50 on ebay, and it's thin enough for me.
I had the case but now I stopped using it because ... well, honestly it annoyed me how close to the edge of the screen the case got and when i was trying to use apps or play games on the phone that required swiping very close to the edge of the screen i kept having to push on the case out of the way/etc.
also ... yeah... i dont really think the case is protecting a whole lot. if anything it just adds some color
Avoid putting it into open front pocket of shirts or T-shirts! Cracked a screen of a camera after 2nd drop out of one. I've had to learn not to use the convenience of my shirt pocket for expensive items because of how many times things fall out (unless buttoned).
It is funny that you mention having trouble getting a case off. I had the same issue today while having to do a battery pull. I just bought this new case today and man was it a pain in the arse to get off. Needless to say I will not be using this case anymore.
I bought a silicone HTC case on clearance at Radio Shack for $3. It's easy to push the sides away from the screen if you need to, but it's almost too easy.
One benefit of this design is that the rear cover surrounds all the corners and rear, so a case is really not needed. If you drop it on a corner and crack the cover, just get a new one.
There isn't much you can do about the camera, it will always be exposed. The only thing that can really protect it is an extended battery case that changes the layout and sits higher than the camera outline... but then you still have the same problem of it not fitting in a dock.
And regarding screen protectors... I use the cheap static films that run about $3 for 3 of them. This week I was doing some field work and forgot my phone was in my pocket and put a few tools in my pocket, then leaned up against my pocket doing some work. I PROMISE it would have absolutely scratched the hell out of the Gorilla glass, it is tough but not invincible. All I had to do was peel off the film and in 30 seconds had a new on applied... screen still 100% mint underneath. It is completely worth it considering you can't even tell it is there when applied and does not reduce sensitivity.
I have it caseless at home, and I usually put my cheap TPU case on every time I leave the house. Most of the time it feels like useless bulk, but the few times I've dropped this phone, I've been thankful it's had a case and screen protector.
To me it just makes sense to invest maybe $3 in protecting a $300 device.
As for screen protectors, I use the cheapest money can buy (though I've been meaning to try a boxwave or steinheil). As long as you don't use a Zagg or similar, the screen feels smooth as ever, though the plastic scratches really easily on the smooth protectors.
If you read anything in this post, make it this: Gorilla glass is strong. It's hard to crack. Rub it with a key or pocket knife all day long, and it won't scratch.
But try taking your phone to the beach and putting it in your pocket with a few grains of sand. Say hello to the thousands of microscratches for me.
Glass can only be scratched by something harder than glass. Most metals you'll find, no matter how sharp or jagged, don't even approach the hardness of gorilla glass. But sand has some pretty hard stuff in it.
It's a personal choice, really. If you want to enjoy your device to its fullest potential, use it completely bare. But if you plan on selling it as "lightly used" for near full price when a new phone comes out, it's worth it to spend a few bucks on a case and a pack of protectors.
I forgot that, but yeah, I do that too. You really need something on the screen and it isn't expensive or troublesome.
I just switched to caseless as well. Just to be safe with the camera, I stuck a few pads (fuzzy/soft half of velcro couplet) around the camera so it's it's propped up a bit when charging. Works really well and now I don't have any trouble popping out the battery when needed.
I've stopped using screen protectors for this reason and because I can never get a screen protector on without some kind of debris behind it. The EVO is the first phone I've had with a glass screen so I'm taking advantage of it.
The Seidio case (can't remember name but it's not the covert case) is a 2 piece design which slides off and on easily enough yet I've never had the halves disconnect. The BestBuy platinum versions are less than 10 bucks with holster on eBay. Slide on when you're out then take off to dock. Best of both worlds. The newer version of the actual Seidio brand has a small kickstand but generally costs closer to 15 where you can get the platinum brand on eBay for as little as 5 with a bit of patience looking for the right auction.
For 15 you can get the platinum covert case which has the 2 piece case then gets a silicon sleeve and plastic skeleton over that inner case for extra heavy duty protection.
This is because when sand is heated to a certain temperature it is made into glass.. That is why it can scratch your phones screen.
