Accessories Case/Holster combo and screen protector
Beardown
Any of you utilizing a screen protector with your case/holster?? I just got my phone 2 days ago and need to get a holster yet. Thinking about the Seidio Innocase II and wondering if I should throw a screen protector on it also. I had the cheaper holster from Verizon for my Eris and no screen protector. Any other holster combos you all would suggest?? Going to get one today. Thanks everyone
I went with the shell/holster from the local Verizon store part # VZW6300hoc1. It's a 2 part deal with a separate shell for the phone and a holster belt clip that the phone, shell and all, slides into. I like it because the shell isn't as bulky as some others I looked at and I've figured out how to use the holster as a stand for the night stand when I use the desktop clock feature as well as a clip mount in my car. I went for the Verizon screen protector as well, Verizon part # VZW6300pksp, and I'm glad I did because as I type this I'm looking at a scratch on the protector that would have been on my screen.
I would look for it someplace other than VZW though. I bought one on ebay for $12 shipping included.
I also purchased the above case from Verizon. My phone kept sliding out of the holster (as I carry it sideways). I even drove off one time and had to go back and retrieve my phone from the grass in front of a client's office! I hated the case AND holster.
I ordered the Innocase and holster from Seidio. Love it! The holster has a spring on the clip and makes it easy to grab the phone but holds the phone securely in the holster. It's FAR superior to any other holster I've seen! It's a little pricey though, but how much is your Incredible worth to you?
I agree, if you can wait, you will find it cheaper.
I bought my DInk on June 14th, it was one of the last (if not the last) pre-shortage DInk's in the state, and I'm a little rough on phones so I needed, to pick up a cover ASAP and this one had just arrived in the company store on June 15th.
I carry mine sideways too and noticed that it wanted so slide out also. I just moved the clip one "click" up so the phone was on a slight angle and haven't had a problem since...though I doubt it will stay put if I end up inverted
