Case-mate Clear Armor
Nepherim
Anyone used the Case-Mate Clear Armor? I'm not interested in the screen protection, but more in protecting the sides, and to some extend the back, particularly as the side paint looks like it's not going to wear very well.
I'm interested in hearing first-hand experience, particularly in terms of how well all the individuals sections stay adhered to the phone. Seems like they'd be prone to peeling off.
I've used Case-Mate Clear Armor on BB Curve, just be advised once its on, its on and if you try and take it off, it there is any type of paint underneath it will come off as well.
YIKES! That sounds horrible! Looks like the cut of it is exactly the same as Invisishield. I'm returning my ZAGG it fails to one thing: Protect the outermost edge. However, this one looks to do that. If it stays on like people say it does, then get it. But I know with the ZAGG, the pointed corners of some of the stickers catch when I put it in my pocket. It ended up rolling the sticker and pulling off the corner. I don't like that, so I'm returning it. But if the Case-mate is semi-permanently affixed, get it; it's a great way to protect without adding bulk.
@DjSmooth: On-is-on would be okay if there weren't 10 separate pieces. As it is there will just be too many exposed clear-case edges. I'll skip this for now, thanks.
