marcelob
Member
Since I'm probably one of the first people on these boards to receive one of these, I figure I'd take some pictures and post them online along with my first impressions.
Now, onto the pics:
As for my first impressions:
Pros:
+ Fits like a glove. Despite the fact that it looks like it might come off easily, it is the exact opposite. It's clear they took their time with making it just right.
+ Very slim while still flush with the camera. Adds minimal bulk and keeps a similar feel to the original backing (but with a bit more grip).
+ Does not push up against your screen protector.
+ Holes cut out so that buttons won't get stuck like with some other cases.
+ Material is hard and will definitely protect the phone's body if it lands on its back and corners.
+ Less than other cases at $19.99 and INCLUDES a screen protector (which you will need since--see cons below)!
+ Looks stylish!
Cons:
- Would probably not help in preventing your screen from shattering due to its hardness. It also doesn't cover any part of the screen or bezel, so that may still get damaged/scratched/dirty. You will want to use a screen protector (the one included or another one) if you plan to protect the screen in a fall.
- Will not help you get a raise at work/laid/a friend/etc.
Very happy with my purchase so far. I came from a VZW silicone case and threw it in the trash. I had to cut out holes for the volume and power buttons since it kept holding them down, and it looked like crap.
Anyways, feel free to ask questions.
Now, onto the pics:
Pros:
+ Looks stylish!
Cons:
