Root Cases and Overclocking
Thrawn
Member
I generally use a 1GHz kernel, although my phone has been able to handle 1.2, but I just got a case the other day because I've already put a few scratches on the black paint and didn't want to do worse. But now I'm worried about the heat with my OC'ing. Does anyone else use a case and overclock? Are there any potential heat issues a case could cause? I haven't noticed anything taking off the case a few times to check, but I want to be sure. My setup is still the same as from before I got the case and it was running pretty darn cool anyway.
I have a Otterbox case and I'm OC'd to 1.1. I don't think having a case will make much of a difference. If your phone is overheating, the case is generally not the culprit.
I was using a Seidio Innocase (that tabs that hold it in place eventually broke) and I was OC'd to 1100 with no problems.
I've been using one of the VZW cases from the beginning with no issues - I'm currently overclocked to 1.1 Ghz
It does get a bit toasty on my Seidio Innocase when I was OC'ed to 1000 but nothing too abnormal. Hell it generated more heat when I was charging the thing than anything.
The only time ive ever noticed heat issues when overclocking is when charging. Not on its own, but when I'm using the phone while charging it.
