Well, i knew about that one. I was hoping you had a link to one that would fit over the full back types like you can find on ebay. Thanks for what you did link, though.
I found 3500mah batteries with extended back for the Incredibles for $26 at Gorilla Gadgets. Got the desktop charger/dock too since the battery was so cheap!
Btw: Hi all! Great forum for the smart phone freaks!
It depends on which extended battery you have. The 2150 only has 1 option from HTCpedia and seidio makes one for their extended battery, thats pretty much it
