GRIMREAPER
Is there such a thing? I want to keep my Epic protected but have had no luck finding one.
i can't believe nobody has found a case to fit the extended battery. ugh, after dealing with dead battery issues with the palm pre, i really wanted to go with an extended battery for the epic. but definitely need the case.
please post if you find a case that fits the extended battery back!
