Im aware there are about a dozen posts on the subject as I have been reading them for the past 2 days, but, there seems to be a lack of comparison reviews so let me explain my situation:
I work in the HVAC field. crawling around in attics working on air conditioning units and the like. The conditions aren't as bad as, say, construction pier hole drilling - But its still likely the phone will be bumped and may occasionally be dropped from waist height or lower, so, I need a bit more protection than a thin scratch protector.
I have heard bad things about seidio cases's wearing out fast. Im not big on the idea of having to replace a case once a month. The Otterbox defender is supposed to be poor quality compared to the stuff they've made in the past; Except for the commuter, which doesn't come with a holster clip and I definitely need that.
So my last option is the ballistic HC it seems. I honestly cant imagine using the optional layer for the bulk it adds to the phone, if its too huge it may actually get in the way of my work. I understand you cant really sacrifice bulk for protection, I was just wondering... How much larger is the phone with the ballistic minus the optional layer, and does it still fit well in the clip? Will it still offer strong bump and drop protection WITHOUT that last layer?
Perhaps somebody else out there has a similar work line and can comment on how they protect the evo?
Thanks.
Thanks.
. The Trident Cyclops is by far the best case! Check it out:
