Root Casio Blues Themed Rom Updated 5/5/2013
monkeytools
First Thing Flash This AT Your Own Risk.
I Am Not responsible For Your Phone Or What You Do With It.
Ok know I got that out of the way. This is a themed stockish rooted rom with a insecure boot.img. All the bloat ware is still there. It is a work in progress and will update as soon as time allows. If you have questions feel free to ask.
A little lesson. An insecure boot.img makes it so you can adb with no special app.
Ok how to install. You must custom Gnm recovery.
1. download Casio_Blue's_rom.zip
2. place in a folder and name it what ever you like.
3. place on sdcard in your phone.
4. reboot into recovery
Know these next steps take your time and make sure of what you are doing.
Warning never ever ever I repeat ever wipe system.
repeat never wipe system!!!!!!!!!! you have been warned.
Optional make a nandroid back up. so you can restore if you run into problems
5. go to wipe
6. Wipe All data/factory reset (know I recommend this but you can skip this part to save your stuff. If you have force close problem go back into recovery and wipe all data/factory reset should solve your problem)
7. wipe cache
8. wipe dalvik-cache
9. go back to main menu and then to Flash zip menu
10. Choose zip from sdcard menu
11. find file that you put on your sdcard
12. flash Casio_Blue's_Rom.zip
13. what until flash has completed then reboot phone.
Phone will take longer to boot than normal.
download here: Dev-Host - Casio blues rom.zip - The Ultimate Free File Hosting / File Sharing Service
Update Zip:Dev-Host - Blues Update.zip - The Ultimate Free File Hosting / File Sharing Service
Credits
Give Willster419 thanks for helping me test and providing the wifi fix.
I want to give credit and thanks too.
Getitknowmarketing for gnm recovery. Thank you sr.
Here is a link to his recovery GNM Recovery
Tommytopdrive for his rooting method. Thank you sr.
Here is a link to his guide http://androidforums.com/commando-all-things-root/659843-m130-rooted.html
forgot spike g sorry sr. thank you for the boot animation tut. here is a link to his how to:http://androidforums.com/commando-all-things-root/508958-how-changing-boot-animation.html
Will be adding screen shots later its been a long day.
If you have any ideas to better the rom please post them. I will take them into consideration on the update. Hope you enjoy this rom.
UPDATE 5/5/2013 The Update Zip is up. It has been highly themed and revamped. You can flash over old rom. If you have problems reflash and do a wipe as per flashing instructions above enjoy.
know I have reboot menu mod working. no need for quick boot app from play store. when you hit power off it will give you a new shutdown menu. select what you want to do and hit ok.
Change log
Update Zip is up theme revamp 5/5/2013
Add boot animation
minor theming done
source code for boot.img here.CASIO G'zOne COMMANDO
sorry for not posting earler still learning. if i need more info posted let me know and i will post. to make sure that i am gpl and gnu compliant.
The first screen shot is with Adw launcher. Don't really like the stock launcher.
whenever i try to update the su bionary, it says the update failed. could not download manifest.
never mind, it was just the update source being down. it works now
I'd love to test this out but the hosting site moves like mud and the download usually quits before 10%. Any chance someone could this file hop on dropbox or sendspace or something? Thanks!
sorry guys I will look into the problem. been busy.
edit Ok try new link. looks like dev host is being slow. so it will take a little time to download. sorry.
the new link worked perfect. Thanks to you, willster, tommytopdrive, and everyone else who have worked to improve this much under-appreciated phone. I look forward to testing this out. Much thanks in advance!
Just as a warning, I would be carefull with that boot image. It was made for M130 kernal and ROM. It sounds like you are on the M110 update, so it might not work. For some reason, it did not work for my M100. Just so you know.
On that note, if you could post your M110 boot.img, I could modify it to allow adb...
I have a serious problem with my Casio C771. I flashed a custom Rom but after the first reboot the phone stuck in bootloader then I flashed boot.img but unfortunately the phone stuck again in the now loading screen. fortunately I made a nan-backup before flashing but I don't know how to restore it
can you get back into recovery.
well the first thing is to define the bootloader. the first time, did the gzone light up and say now loading, or did it stay unlit just at gzone?
Good work to all involved. I've been on the 'outside' reading these forums and doing everything verbatim to root my m130, then install the red rom, and just now the blue rom. When I installed the red rom, I did as recommended and did the factory wipe. I noticed that the apps that I did a titanium backup on, I could easily have back on my phone after the factory wipe. When I just did the blue rom, I didn't wipe anything. Everything works, but my keyboard is still red. No big deal, it's kind of cool << cognitive dissonance
Thanks!!
I do all step but my phone don't get any service the only the wireless work but, I can not make call. Someone can help I have a C771 M130.
In the My phone number say: Unknown
In the MEID say: Unknown and the Mobile network type say: Unknown
I am not sure what version I had before now say M130, I restore the backup and I get all data back but the only connection I get is the wifi no get cellular service.
I enter the ##7764726 and the password 000000 and give me a read error!!
I check the nandroid and yes I have the complete files, You know what files can I flash back to recover the phone service
just some more questions so i can try to narrow down the problem. is this a recently rooted phone, or were you rooted before? also, I don't want to sound like a creep but people have had problems with rooting, ROMs and having cell service in other providers with some sort of "bring your own phone" program, for example if you are using your phone in India, and had to manaully enter the information. Does that apply to you?
if it has nothing to do with the ladder, my best guess is that your kernal/origional os was not M120 or higher, and was prob around M80 or lower, back when they had a different system for radio service.
if you have an old nandroid that was working before i would flash that, then do a verizon OTA update, so your phone can accept the necessary changes needed to install these new ROMs.
